International 330
HoneyRancher
05-11-2004 15:13:11
I am looking at this for a working tractor - mostly mowing. Is there anything specific I should check for in addition to all the standard stuff?
I think the HP is about 35 - it has the C-135 engine. Can someone verify the HP for me?
Also would like to hear any stories (good or bad)from owners or users.
Thanks for your help.
TDK
05-11-2004 23:47:47
 Re: International 330 in reply to HoneyRancher, 05-11-2004 15:13:11
The 300/330/350 series tractors are good dependable tractors. But all have their weaknesses. Check steering play, is the loosness in the box, steering arms on box or spindles, spindles themselves ? It's surprising how much play that can be eliminated by simply tightening str. arm nuts and/or replacing bad tie rod ends. Look for damaged/bent/welded steering arms, this can be an indication that steer. box has internal damage. We have 5 300/350U's and two of the five have had gearbox damage. Parts for box are hard to find and expensive. Don't let this sound like I'm discouraging you, a tractor is only as good as how well it's been maintained & how it's been treated. Both of the ones we have that suffered gearbox damage was due to people running them into things and breaking gearbox internal parts.
One look at the steering arms(twisted,bent,welded)tells the story. Brakes usually need attention on these models, though not very costly. Well You did ask for a story. So I went on and on. The H.P. is 35. I would highly recommend one of these tractors, hope to have one myself one day. Thes are just a few things to check and to take into consideration when negotiating a price. Feel free to e-mail me if I can be of more help.
r4etired
05-11-2004 18:57:21
I have a 330 with the 135cu in.it depends what type of mowing you are doing. mine has 2400 actual hours in real good condition. it realy works it to pull my 6ft rotarywhen the grass is a foot tall.I have a problem with overheating. It just works great with a cycle mower
