Help on leaking rear axle housing pans
Keith(Texas)
05-11-2004 17:05:08
I need help on leaking pans. Just finished restoration on my Super AV and everthing turned out great except both rear axle housing pans leak excessively. I used new gaskets without any sealer and tightened the bolts progessively from side to side. Any suggestions on fixing this condition would be appreciated. Thanks, Keith
James
05-12-2004 19:36:43
 Re: Help on leaking rear axle housing pans in reply to Keith(Texas), 05-11-2004 17:05:08
Keith can you e-mail me at tmhardi@aol.com? I would like to talk to you about your SAV. I am looking for an AV myself. James Hardin in Houston,Tx
James in Houston
05-12-2004 17:42:46
You might make sure the bolt hole surface is flat. I have put pans on the edge of a work bench and tapped on the bolt hole surface with a hammer to true them up. If you use silicone make sure the surface is oil free. You might try a little thicker gasket. Good luck
david
05-11-2004 21:23:11
I made new cork gaskets for my B, and shellacked (sealed)the heck out of them. Been a year, and no leaks so far. I know what it's like to paint a tractor, and have a leak when it's done. Good luck
gene b
05-11-2004 18:43:32
I use the black stuff from PERMATEX two tractors have been on the TRACTORCADE rides for two yrs 175mi each year and no leaks. I use 90wt gear lube.
