1086D Vapor Lock??????
Bill W in Ohio
05-11-2004 17:06:56
Last Sunday I was discing ground for a friend with his 1086 Diesel and when I finished one field after an hour, and was going to the next one, I stalled the engine,(low rpm, tried to back-up). It would not re-start. Left it for a half-hour or 45 minutes and it re-started right away. My Question--What to look for, or is there even a problem???
Thanks in advance,
Bill W.
supermpuller4
05-11-2004 17:25:28
 Re: 1086D Vapor Lock?????? in reply to Bill W in Ohio, 05-11-2004 17:06:56
Pump won't keep presure when hot or at low rpm ,probably needs rebuild.If it will start cold don't let it idle below 900 rpm and don't kill engine when hot, the pump will last a while but its time to get it looked at.
