Can you put duals on an H
Dan
05-12-2004 07:31:05
i was just wondering if it was possible to put duals on my H. traction in some spots my tractor is lacking. like when disking.
Farm w/Junk
05-12-2004 12:19:54
 Re: Can you put duals on an H in reply to Dan, 05-12-2004 07:31:05
Hey yea you can put them on. I had a set on my H all last summer. I have a set of snap on duals that are nice if you will want to switch back and forth or run a plow. I restored the tractor this winter and have no use for the duals. If interested email me.
Matt
scotc
05-12-2004 09:02:59
snap-on duals would work too, just need to change from standard nuts to looped nuts on some of your wheel clamp bolts
George Willer
05-12-2004 08:00:33
third party image
Yes it's possible. Mine has the optional 100" axles so there's a lot of extra room. The axles stick out 24" on each side. Now that I've done it, I can see that it would work on standard axles that only stick out 14".
My fenders are set out 5 1/2", and still have 5" clearance.
George Willer
ellson
05-12-2004 16:30:09
 Re: Re: Can you put duals on an H in reply to George Willer, 05-12-2004 08:00:33
I have duals on my H with regular rear axle but am not as computor literate as George and can't post a picture. With fenders the operataor platform is very conjested. If interested I could e-mail a picture
mike in mo
05-12-2004 09:10:49
hey George great looking tractor did you use clamp on duals or just 2 sets of wheels and centers.
CNKS
05-12-2004 07:33:38
Someone will probably post a picture, inner wheels dished in, outer ones dished out. Dunno how much adjustment you have after that.
Dick Davis
05-13-2004 03:23:19
 Re: Re: Can you put duals on an H in reply to CNKS, 05-12-2004 07:33:38
CNKS not very d--- much! On my M with 13.6's there is not enought room for the fenders and it is a little nervous with tires rotating so close to your body. Dick Davis
