Super H Brake Shafts (Worn Splines)
Dave
05-12-2004 10:10:44
Has anyone had success building up with weld the splines on these brake shafts? The area on which the brake disc ride typically wear. I would like to replace with new but have not had much success locating these. I would appreciate any information regarding anyone having any new old stock of these.
PeteNY
05-12-2004 13:35:17
 Re: Super H Brake Shafts (Worn Splines) in reply to Dave, 05-12-2004 10:10:44
Dave, I just bought a pair of perfect ones from a guy here in Upstate, NY...$35.00 each including the bearing. They should be available as the 300's were the same part #. Email me if you want his info. Pete
Dave
05-12-2004 16:30:11
 Re: Re: Super H Brake Shafts (Worn Splines) in reply to PeteNY, 05-12-2004 13:35:17
Pete,
Thanks for the reply. I will send you an e-mail.
Dr.EVIL
05-12-2004 11:50:52
I would not recommend welding. Those shafts are carburized, hard on the outside and softer on the inside, and the hardness tends to propogate cracks. Since the pinion gear is part of the shaft You really have to watch what You do to it. I'd look in the local larger city phone book yellow pages for "Machine Tool Rebuilders" can call them. They either can rebuild gears/shafts or know someone who can. They will possibly anneal or normalize the shafts, plasma spray weld the splines & re-grind them, then re-harden or chrome plate them and regrind. A used pair of shafts would possibly be cheaper. A lower cost alternative would be to have the machine shop grind off some of the center cast iron brake actuators, and the inside of the cover so the brake discs run in a different area of the splines.
