Order Farmall Cub Parts Online
bvpassing cub on-off switch
carl in nc
05-12-2004 17:52:49
I need to cultivate my garden with my cub before I take time to replace the push-pull switch which has broken in half. What can I wire straight from the battery to what part of the ignition system to run the tractor? ( coil, distributor,etc.)Thanks. Right now I have battery pos. cable disconnected.
49 Cubber!
05-12-2004 19:02:25
 Re: bvpassing cub on-off switch in reply to carl in nc, 05-12-2004 17:52:49
Hook a wire from the post on the starter to the side of the coil that comes from the switch.I have a setup I made with a couple of alligator clips for that purpose.The starter is easier to get to than the battery.
carl in nc
05-13-2004 19:29:30
 Re: Re: bvpassing cub on-off switch in reply to 49 Cubber!, 05-12-2004 19:02:25
worked great. Thanks for the help.
Bigdog
05-12-2004 18:50:42
If you have battery ignition, and a 6 volt positive ground system you can run a jumper from the battery negative post to the negative coil primary terminal. If your system is negative ground, it will be positive post to positive terminal on the coil. Your system should be positive ground if it is 6 volt but many got switched over the years. If it is 12 volt, it will be negative ground so run positive to positive. As usual, when by-passing any component, use extreme caution. You could temporarily stick a toggle switch into the dashboard and wire it. There are only 2 connections.
Rudi
05-12-2004 18:24:18
third party image
Carl:
I am really lousy at electrical problems and schematics, but ---- there are schematics around.
Check out>Link
Oh, you can also go to the manual server at the link below and check out the Blue Ribbon Service Manuals, they are chock full of stuff.
