90 wt. or 80-140 multi- wt. oil??
John
05-12-2004 19:10:12
What grade of oil should I be using in my 154 final drives and Farmall H transmission. I have been using Kendal 5 star GL-5 80-140 multi-wt. and was wondering if maybe I should switch to IH. 90 wt? Thanks!!!
Don L C
05-13-2004 11:05:02
 Re: 90 wt. or 80-140 multi- wt. oil?? in reply to John, 05-12-2004 19:10:12
80-90 you can get it at Tractor Supply Store..
Doug in OR
05-13-2004 07:44:07
I usually vote for the oil that is newer and better. In this case, I won't do that. First of all, I'll assume no hydraulics are involved. Next, GL-5 gear oil didn't exist when your tractor was designed. A common belief is that GL-5 is an acceptible or even better substitute for GL-4, or even GL-2. This is not the case. They are specified to meet different applications. The transmission of my Nissan is specified to use only GL-4. I made the mistake of using GL-5 in it, and guess what? Major gear grinding. The syncros just didn't appreciate the GL-5 composition. GL-5 was not designed as a replacement for GL-4.
My advise: Unless you know more about the oil you are using, I'd stick with the gear oil that your service manual recommends.
49 Cubber!
05-12-2004 19:22:32
My 154 has Hytran in the tranny and final drives,its what it calls for.I have 90 wt in my H,dont know what makes it,I think GRC.
