49 Cubber!
05-12-2004 19:20:56
Put my tranny back toghether for the third time over the weekend.I hope I have it right this time,that top is getting heavy!ANywho,spent today going over it good and checking this that and the other on it and ran it for a good 9 hrs,then i realized,I NEVER CHANGED THE OIL.I know the tractor sat for about 5 years before I got it back in January,and I was afraid I had messed up something but fortunately I didnt.I changed the oil and immediatly my oil pressure was up to 80 at full throttle and 55-60 at idle,granted those numbers couyld be off some,cheapo depot gauge that was on it when I got it,plan on changing it soon.Some of the things I noticed,and want you alls thoguhts:Under load,I get some black smoke,no smoke at idle ot full throttle under no load,second there appears to be a good deal of smoke coming from the vent tube on the lifter cover,but that could be from the oil needing changed,I didny run it much other than to check for leaks when I finished changing the oil so I dont knowe if it was still doing it or not.Third,refresh my memory but isnt there a seal on the upper bolster at the back side where the steering shaft comes through.Ive got a leak there,but no biggie.Finally,this is tough to explain,my steering wheel shakes,not just the wheel,the whole thing,light bar,throttlel ever and all.I noticed that the shaft from the ujoint up isnt doing it,just the entire section from the joint back,and this is in third gear,just third,not any other.Thanks alot fellers!
