Order Farmall Cub Parts Online
Cub Compression psi, if you please...
Rob Cub
05-13-2004 07:28:57
So I got my Cub cranking - compression is, in order, 80, 90, 25 (!) and 100 psi. Obviously, I'll be looking at cylkinder 3 - starting with a stuck valve (wouldn't that be nice?). The shop manual, however, doesn't state what compression should be.....do you guys know?
Thanks!
Rob
justin
05-13-2004 13:30:01
 Re: Cub Compression psi, if you please... in reply to Rob Cub, 05-13-2004 07:28:57
The IH serviceman's handbook for tuneup specs shows that the cub should have 125 psi of pressure at cranking speed.
Rudi
05-13-2004 09:11:31
third party image
Rob:
Not sure offhand what the compression should be, but the Blue Ribbon Service Manuals on the server at the link below do have that information.
Hope this helps
