Will 85W-140 GL5 gear oil be ok in my trans/diff?
Greg
05-13-2004 10:44:33
I serviced my 364 diesel trans/rear diff and was told to put 85W-140 GL5 gear oil in. I did it but now wonder if it was the right thing to do. A service manager at an IH dealership gave me the advice but I wonder if 80-90 would have been better or if it really matters at all? The fluid that came out had no water in it from condensation and everything looked fine, I just want my tractor to get the fluids it needs to last as long as possible. Thanks.
Don L C
05-13-2004 11:00:21
 Re: Will 85W-140 GL5 gear oil be ok in my trans/di in reply to Greg, 05-13-2004 10:44:33
140 is a little stiff in the winter temps..... if you live in a mild year around temp. it will be OK.....If it is hard to shift gears, you could add a qt. or two of heating oil.....
Greg
05-14-2004 12:03:19
 Re: Re: Will 85W-140 GL5 gear oil be ok in my tran in reply to Don L C, 05-13-2004 11:00:21
Don, the tractor is run in the East Texas area and winter's are very mild. Rarely below freezing but the summers pound us with 100+ heat regularly. I bet it will be fine. I'm not worried about the hard shifting but was concerned about it doing a good job lubing all the gears and bearings and hurting my trans in the long run. The tractor will be run mostly in the summers so I feel ok about it now.
