'47 McCormick WD-9 3-pt.
Gary W
05-13-2004 11:49:30
Do these tractors hav 3-pt. hitches? Saw one adveritsed and it did mention hydraulics but not 3-pt.
Joe Evans
05-13-2004 12:48:37
 Re: '47 McCormick WD-9 3-pt. in reply to Gary W, 05-13-2004 11:49:30
They do not have 3 point hitches unless some adventurous tinkerer added one. Someone needs to check me on this, but I seriously doubt if the follow-on offspring of the WD-9 (Super WD-9, 600, and 650) were offered with a fast hitch option.
I reserve this caveat: as soon as I think I know something, I get my lunch handed to me.
Allan
05-13-2004 14:19:01
 Re: Re: '47 McCormick WD-9 3-pt. in reply to Joe Evans, 05-13-2004 12:48:37
Joe,
"I reserve this caveat: as soon as I think I know something, I get my lunch handed to me."
LOL! Me too, every darned time!!
Allan
Wardner
05-13-2004 13:12:09
I guess I must be that "adventurous tinkerer" that you mentioned. I have a 650 with a fast hitch. I built it with 450 and 706 FH parts. It has a top link attachment point so that it can be converted to three point hitch.
It is extremely rugged in that the attaching hardware is cut from 1" plate. It has two verticle lift cylinders. It looks good enough so that many have walked away scratching their heads.
I would send a picture but my scanner is busted. I will check later to see if I uploaded images to this site. I kinda doubt it because I know that previous uploads of the tractor went to Photopoint.
Joe Evans
05-14-2004 05:50:14
 Re: Re: Re: '47 McCormick WD-9 3-pt. in reply to Wardner, 05-13-2004 13:12:09
That would be neat to see. Sounds like a trick set up. What size plows have you been able to pull with that fat beast?
I have an affinity for that type of tractor. I have a W-9.
Wardner
05-14-2004 18:15:58
 Re: Re: Re: Re: '47 McCormick WD-9 3-pt. in reply to Joe Evans, 05-14-2004 05:50:14
I only used it once for plowing. I bought a cheap 4-14 FH plow. I hauled the rig to a plow day in Central Mass. Everybody was having problems. It was an old rocky pasture on a hillside. I have had better results with a 3-14 FH plow behind either my MTA or 400.
The tractor is currently setup with a fork lift mast and a utility company pole hole auger. Hydraulics come from a 22 gal Prince PTO Pump. It digs very nice holes.
