farmall H radiator
Dale Lusti
05-13-2004 14:52:51
While trying to remove the radiator of off my H the nut on the mounting stud was rusted and I twisted it off. Now what's left of the stud is lose and leaking. Can the studs be replaced and where can you find them
Nebraska Cowman
05-13-2004 17:48:33
 Re: farmall H radiator in reply to Dale Lusti, 05-13-2004 14:52:51
if it's leaking you got problems. Likely your best bet is to get a new radiator. new studs should come with it. if they don't I'm sure I have some.
dale lusti
05-13-2004 20:28:10
 Re: Re: farmall H radiator in reply to Nebraska Cowman, 05-13-2004 17:48:33
Nebraska Cowman,thanks for the reply. It appears to be leaking around where the stud scews into radiator.Do you know if the stud srews into the water jacket (tank)or should'nt it leak when you pull the stud out ?
Wayne Swenson
05-14-2004 06:19:33
 Re: Re: Re: farmall H radiator in reply to dale lusti, 05-13-2004 20:28:10
The female portion to the mounting system is soldered into the bottom tank of the radiator. Take the radiator to a radiator repair shop and they can fix it at a reasonable cost compared to buying a new one. That is if the old one is in decent shape otherwise.
Dale Lusti
05-14-2004 13:16:45
 Re: Re: Re: Re: farmall H radiator in reply to Wayne Swenson, 05-14-2004 06:19:33
Wayne,
Thanks for the reply. I think I know of a radiator shop that should be able to handle it. Thanks for the advice.
Dale
