International 464 diesel
Hazlett
05-13-2004 20:37:31
I recently purchased a 1975 international 464 diesel, i paid 4500 for it and it only has 3000 hrs. it has a 3 point and a front loader, i was wondering... there is a small lever/pedel on the right side rear part of the footwell, could someone please tell me what this pedal is? it appears to be stuck now, but i just picked this tractor up today (5/13/04)i am also having problems with weight, when i load the bucket with dirt, i lose alot of traction, there is nowhere to put weight on the back, im open to suggestions. any other information/things to watch out for would be appreciated. Thanks
buck
05-13-2004 21:38:50
 Re: International 464 diesel in reply to Hazlett, 05-13-2004 20:37:31
Pedal is traction lock--locks both rear wheels together so they pull the same. should lock wheels when depressed and release wheels when you release the pedal-otherwise does sorta appear stuck. fluid in tires,wheel weights.heavy implement on 3 pt. or a drum fixed to attach to 3 pt. and filled with sand,gravel ets or even a drum of water on a carryall will add the needed weight to rear. Very nice tractors.
