Order Farmall Cub Parts Online
Need help with cub pto
Paul Shuler
05-15-2004 14:24:12
A good buddy of mine called me this morning and is haveing trouble with his cub. It has a woods mower deck on it. He said while mowing it started makeing a high pitched noise then the mower froze up. He took the belt off and his pto is froze up tight. It did not stall the engine.So he thinks it's the pto and not the mower deck. Have any of you had this happen befor and if so what is the best fix. I don't know the year but the link below is a photo of the tractor.
ji,mmy z.
05-15-2004 15:32:41
 Re: Need help with cub pto in reply to Paul Shuler, 05-15-2004 14:24:12
paul, have your buddy remove the shifter plate and check the shafts and gears if you are sure the pto froze, not the deck[ or pullies etc.]
there is a slidding collar that engages the pto shaft to the trans. look around and try to determine if a tooth broke off or something else jammed. best of luck. nice picture! jimmy z.
