Order Farmall Cub Parts Online
Need help timing rotor to mag on cub
Chris
05-15-2004 17:00:35
My grandpa said his cub was lacking power when he was mowing and it was about time to file the points so I did. When I put them back in I think I screwed up because it won't start now. Can anyone tell me how to get everything back in time(rotor in time with evrything else. Any and all info would be greatly appreciated. Thanks.
Jim Becker
05-15-2004 17:13:20
 Re: Need help timing rotor to mag on cub in reply to Chris, 05-15-2004 17:00:35
Assuming you didn't remove the entire magneto, and you have the points gapped near correct, all you need to do is get the rotor back in position. The pinion that drives the rotor has one tooth with the corner clipped off. The rotor has a rib opposite the point. Line the rib up with the clipped tooth.
Chris
05-18-2004 18:33:21
 Re: Re: Need help timing rotor to mag on cub in reply to Jim Becker, 05-15-2004 17:13:20
Thanks Jim. Your instructions worked perfectly. I am now back in good graces with grandpa thanks to your help.
