How much oats should I buy?
Kelly C
05-15-2004 18:30:46
I plowed up that 6 acre field today. My 400 was having fun. Going to disk it and drag it tomorow.
How many pounds of oats should I buy to use as a cover crop for my Alfalfa? I picked up 100 pounds of a Alfalfa/ timmothy mix today. Counter guy said that was what I needed for 6 acres. No one around here has oats. All the seed guys are out around here so will go hunting for some.
If you got some seed oats in Central MN let me know.
Keith T
05-16-2004 13:17:59
 Re: How much oats should I buy? in reply to Kelly C, 05-15-2004 18:30:46
What we have here is a problem .Do we want oats to harvest or do we want alfalfa ?In central Illinois if you plant 3bu.or 200 which is about 5 bu. they will grow up fall over and kill out the alfalfa.I put no more than 10bu.on my 7ac. field when Iwant a decent stand of alfalfa.
Rick L.
05-16-2004 21:46:18
 Re: Re: How much oats should I buy? in reply to Keith T, 05-16-2004 13:17:59
We mow and bale the cover oats when in the dough stage regardless of the height of the alfalfa. Makes good cow feed through a processor. The alfalfa makes a good stand afterward. We can't leave the oats to compete for moisture after this point anyway, so we don't ever figure on a crop of grain.
Rick L.
Nebraska
steve450
05-16-2004 09:14:19
Kelly, we just seeded down 10 acers of grass hay and used 1.5 bu/ac of seed oats for cover. planted 2 weeks ago and the oats are 3 inches high already. The grass is just starting to poke through.
Thanks- Kelly C- Messure
05-16-2004 06:46:58
Thanks guys. I found some seed oats up in Oglvie,MN sold bulk. Need to see if my trailer can hold 12 bushels, What the cubic inches for a bushel of oats?
riverbend
05-16-2004 11:30:32
 Re: Re: How much oats should I buy? in reply to Thanks- Kelly C- Messure , 05-16-2004 06:46:58
A bushel is 1.25 cu. ft.
Kelly C
05-16-2004 13:20:32
 Re: Re: Re: How much oats should I buy? in reply to riverbend, 05-16-2004 11:30:32
Thanks.
I picked them up today. The guy bagged it for me.
Didnt get the land disked today though. My 400 started acting up. Kept loosing power and sputtering. Its starving for fuel at full rpm when the govoner kicks in. Let it idle for a bit then can haul butt for a few 100 feet more then starves again. Something must be blocking a fuel line or the sedement bowl. Drat!!! wanted to get that done today.
riverbend
05-16-2004 15:35:25
 Re: Re: Re: Re: How much oats should I buy? in reply to Kelly C, 05-16-2004 13:20:32
Welcome to farming. Planting after you get a little shower should be almost as good.
RickB
05-16-2004 03:13:51
In this neck of the woods (NY) most guys stay aroud 2 bu/acre for an oats cover crop. 3 bushels is fine for straight oats, but you need to back off a little so they give the alfalfa a chance.
Jim
05-15-2004 22:34:23
Kelly, I like to put on 100 pounds per acre of seed oats or 200 pounds per acre of bin oats. If you take oats out of a bin and run them through a seed cleaner put on at 200 pounds per acre you will never know the difference.
Marvin(MN)
05-15-2004 21:35:18
Kelly, Carlton Feed Mill has seed oats and also bin run which they say germinates real well.HTH
Marvin
John A
05-15-2004 20:41:31
Kelly, If the seed oat dealers are out....Go to the feed store and buy the biggest bags of feed oats you can find. Being that they are for just cover and there is only 6 acres to it might be a little more cost but not that much on just 6 acres. Just a thought.
Later,
John A.
Alvin NE WI
05-15-2004 19:38:26
figure in the range of 2-3 bu. per acre, and not over 3..
