Super WD6 Hydraulic pump
Eric
05-16-2004 11:34:20
Using SWD6 today Hydraulic Pump and all associated hydraulic pipes and resivior got so hot. I am sure I would have scallded myself had I touched the pump housing left it to cool down and tried it again got very hot quite quickly and also started leaking oil from pump joint gaskets and also through distributor.the only hydraulics being used was the power steering. I realise i need new pump seals, but can anyone shed any light on what may have gone wrong to cause pump to overheat. thanks in advance Eric....
Geoff NY
05-16-2004 14:34:36
 Re: Super WD6 Hydraulic pump in reply to Eric, 05-16-2004 11:34:20
Don't know yet, but I was disking with mine this morning and blew the gasket at the distributer. There was so much pressure that everything in a fifteen foot area got a bath in hydraulic fluid. I know I've gotten water in it before. Maybe the bearing went and the seals, or the relief valve failed. Will post more when I get into it. Geoff
