IH 340 Utility Starter
Rocky
05-16-2004 16:50:21
What is the best way to go about removing a starter from a 340 utility? Looks like the main hydraulic feed line right behind the starter needs to be taken loose but not sure. Hate to take something loose if not necessary. Thanks for any help.
Catskill Pete
05-16-2004 17:09:51
 Re: IH 340 Utility Starter in reply to Rocky, 05-16-2004 16:50:21
Yes, you have to unscrew the hydraulic line to get the clearence to get the starter out. Not that big a deal, remove the side cover of the battery box to get at the fitting, then just back out the upper fitting and move it out of the way. I might add there is very little fluid loss doing it.
Rocky
05-16-2004 18:55:40
 Re: Re: IH 340 Utility Starter in reply to Catskill Pete, 05-16-2004 17:09:51
Thanks very much for your help. It's greatly appreciated.
