Tractor won't start
Dan Agius
05-16-2004 18:42:18
I have a 1944 Farmall BN. I have totally rebuilt the engine. I'm sure it is done right, but it still won't start. It is getting spark, it's timed correctly, not sure if it's getting gas. Any suggestions what my problem might be? Any advice is really appreciated!
Thanks.
Dan
peterc
05-17-2004 19:02:07
 Re: Tractor won't start in reply to Dan Agius, 05-16-2004 18:42:18
check your valve adjustment on a rebuild if the valves are to tight it wont want to run. set them a couple of thousanths wider than it calls for and reset to specs after it is hot.
Randy in NE
05-17-2004 05:07:42
There are only three things that you need to create combustion. Air, fuel, and a spark. You say that the engine is timed correctly. Are the plug wires on in the correct order? If the wires are sequenced counter-clockwise while the distributor/mag is going clockwise it isn't going to fire correctly even if you have it timed at TDC for #1. Are you getting gas to the inlet of the carb? Loosen the inlet fitting or loosen the drain plug. Is the float sticking in the carb? When you are trying to start it do you smell unburnt gas? Are the plugs getting wet from gas being drawn into the cylinders but not burning? Was the engine running prior to you re-building it? Do you have fresh gas in the tank? Just several things to think about.
