Which Farmall for Loader Service?
Paul in NJ
05-16-2004 20:40:28
I'm just finishing up restoring a 51 Cub. I'd like to restore another Farmall, but this time one that I can eventually locate and fit up a hydraulic front loader rig to for general use. I've heard I'd need live hydraulics to do this. My understanding is that this puts me into the "Super" series Farmalls produced in 1953-4. Which size Farmall would be recommended for this? Could I do it with a Super C, or have to go up to a H or M? Any experiences and/or comments would be greatly appreciated.
26Red
05-17-2004 12:48:15
 Re: Which Farmall for Loader Service? in reply to Paul in NJ, 05-16-2004 20:40:28
I have an H with a 250 Du-All loader on it. It's a heavy duty all- hydraulic loader with a pto pump. It works pretty well, but powersteering would be nice. I'd look for a M with a similar type loader and powersteering.
Steve - IN
05-16-2004 23:03:00
third party image
Paul -
You don't need live hydraulics - but they're surely nice to have - so you may want them. Without them, you do a little dance from the clutch pedal, into neutral, lift the bucket, then back to the clutch and into gear. It's actually easy, and second nature once you've grown accustomed to it. The other point is that any letter series Farmall is likely to have a trip bucket - so the only time live hyrdaulics come into play is when you have the clutch disengaged and want to lift.
Economics say you'll want to get the loader with the tractor, as any separate add-on you'll find afterwards will usually dent your wallet more than having the loader thrown in with the tractor when you buy the tractor. Also, you'll most often find loaders on H's and M's. I can't recall seeing one on a C. The factory loaders, like the 33A on mine have very small buckets -- and with good reason. They can't and shouldn't handle much load, and shouldn't be lifted very high. Think of the whole setup as a nifty way to clear the milking parlor of manure at a rate of one wheelbarrow load at a time, then lift it as high as needed to clear the side of a manure spreader; and you'll have a good grasp on the capabilities of the loader.
Another bit of experience I can offer is that you'll use the loader maybe 5 to 10 per cent of the time. Rest of the time, it's in the way and generaly a pain in the rear -- so think about an overhead lifting system that will make it easy to attach and detach the loader when you don't need it.
Here's my H with the loader on. No live hydraulics, and a simple trip bucket (it's either holding the loader, or it's dumped it - no angles in between). If you take your time, and know their limitations, the old style stuff can do the same jobs -- it just takes you a while longer.
Good luck in your choice.
Steve
Paul_NJ
05-18-2004 20:09:04
 Re: Re: Which Farmall for Loader Service? in reply to Steve - IN, 05-16-2004 23:03:00
Steve
Thanks for the information and the photo of your H. Can you tell me approximately how much weight the bucket will lift? For example, could I pick up a 100-200 pound log?
Thanks
dhermesc
05-17-2004 06:56:25
What model of loader is that? It looks exactly like mine. I picked it up for a $200 and then had to rebuild the cylinders. Trip bucker loaders always seem to go extremely cheap compared to hydraulic dump. You can do a lot of work with a trip bucket, on some simple jobs it even faster then a tilt bucket (especially with older equipment). If your hydraulics are in good shape a quick snap of the lever will pop the bucket back into place.
Another thing to consider is buying a number series - like a 300 or 400. For some reason they tend to be about the same price as the letter series but have options like live PTO and hydraulics.
Steve - IN
05-17-2004 18:29:45
 Re: Re: Re: Which Farmall for Loader Service? in reply to dhermesc, 05-17-2004 06:56:25
If memory serves, it's an IH model 33A. I had it all researched and figured out at one point as I wanted to find the original decal for it. After stomping over the entire Portland show with no luck, I put aside all the info, and am not quite sure where I put it at this point -- such is life.
You're right, it's a good little loader as long as you don't get too ambitious with it.
rustyfarmall
05-17-2004 05:05:06
Steve, you said it all very well. The only thing I might add is if you can have one tractor dedicated to loader work, then there is no need to remove the loader.
Steve - IN
05-17-2004 18:34:23
 Re: Re: Re: Which Farmall for Loader Service? in reply to rustyfarmall, 05-17-2004 05:05:06
Probably shouldn't admit it - but my other two tractors are green. I like to hear the old red one purrrr like it does, so I do have a reason (even though a bit quirky) to pull the moveable parts and the cylinders. A guy named rustyfarmall isn't gonna tell me to use the green tractors instead, is he?? Ha.
Thanks for your note, take care,
Steve
Farmall Doctor
05-17-2004 09:49:58
third party image
Here's our Farmall 230, with a #32 IH loader. It is all we have ever had on the farm for a loader, and it will surprise most people with how much you can actually get done with it. The C through the 230's have live hydraulics, so no worries there. Regards, FD
