Measuring crank for bearings
Will
05-17-2004 06:01:30
Does anyone know of an easy way to do this? I bought a B recently that was semi-taken apart and when I began looking at the bearings in the bottom of the box, I found three standards and one that was .020 over. I'm guessing I won't see the difference in the journals. I have a caliper set-is this the best way to check everything out?
Will
scotty
05-17-2004 06:43:45
 Re: Measuring crank for bearings in reply to Will, 05-17-2004 06:01:30
Will, Your best measurement would be to use a micrometer. You can measure within .0001, a tenth of a thousanth.
scotty
Will
05-17-2004 16:58:02
 Re: Re: Measuring crank for bearings in reply to scotty, 05-17-2004 06:43:45
Appreciate the advice. Probably going to measure her middles tonight. Hopefully, hopefully I can get this old girl moving along soon. She's in awfully bad shape.
