Rear tire size for Farmall 504
Tom
05-17-2004 13:37:22
What is the standard tire size (rim dia.) that the 504's came with. Mine looks like it sits lower in the back. Thanks in advance!
Tom
Tom
05-19-2004 09:17:00
 Re: Rear tire size for Farmall 504 in reply to Tom, 05-17-2004 13:37:22
Thanks alot guys for the info. I will be replacing both tires and rims in the near future because of deterioration. Can I fit a 38" rim on the wheel hub? Are the inside diameters the same on a 36" and 38" rim for this tractor? Thanks in advance.
Tom
Joe
05-18-2004 10:02:00
13.6 x 38's on my 504, sits a lot like the one in Joe's picture, think mine's a lil higher in the front from a bigger tires on the NF. I know they'll rub the suitcase weights when ya turn..
Wardner
05-17-2004 22:19:43
Nebraska tested the tractor with 13.6 x 38 rubber. This size is used on my F504. The tractor looks level but it has a Schartz wide front.
Joe Evans
05-17-2004 19:30:27
Tom: our 504 is equipped with 13.6x38 tires. Check this link below--it's a picture of our 504 with new 38" rubber. See if it sits like yours does.
Hugh MacKay
05-17-2004 18:21:56
Tom: Quite sure the one I had was 13.6x38 and it would have come from factory that way.
Ken Koch
05-17-2004 21:45:43
 Re: Re: Rear tire size for Farmall 504 in reply to Hugh MacKay, 05-17-2004 18:21:56
I have a sales brochure for the Farmall 504 and it gives the specifications on the back page. Tires: Front:6.00-16 in., 4 ply (F2) rim 4.25 KA. Rear: 12.4-36 in., 4 ply (R1) rim W 10-36. Under Special Equipment it lists Tires: Front: 6.50-16 in., 4 ply (F2) rim 4.25 KA (For tractors with wide front axle). Rear: 13.9-36 in., 4 ply (R1) rim W 13-36. Also the Ground Speeds chart shows the speeds with 12.4-36-in. tires. I will scan this brochure and put it on Vintage Ads photos. Good luck.
