Wiring help
Mike S
05-18-2004 16:02:08
My 1952 Super A has had all of the wiring disconnected. It appears to me that someone has changed it over to a 6 volt negative ground. Since there's no generator, does it really matter?
CNKS
05-18-2004 17:54:59
 Re: Wiring help in reply to Mike S, 05-18-2004 16:02:08
If you are saying it has a mag, and you are using the battery just for starting, it doesn't matter. Even with the generator, it doesn't matter, as long as the generator is polarized correctly. If you have an alternator, I think it HAS to be negative ground, someone will correct me, otherwise.
Mike S
05-19-2004 07:20:44
 Re: Re: Wiring help in reply to CNKS, 05-18-2004 17:54:59
Sorry, I should have been more specific. It has a coil. The coil negative post is hooked to the distributor and the positive directly to the starter (with a disconnect) They have completely bypassed the on off switch
