farmall A
tiny
05-18-2004 17:30:16
ON my A I took the fuel tank off and cleaned it and the sedamint bowl and soaked it in lacquer thiner to clean it,put a new fuel filter on, re assembled it and it still acts like it is starving for fuel will not trotle up with out stuttering, and when you put the clutch in to start the pto it dies.
It started doing it when I was mowing the yard and would not come out of it. Is what Peabody talking about on the Zenith carb?
Peabody- "Don't forget there is a filter screen in the gas line elbow going into the carb. Detach the elbow from the carb and check the screen for crud. "
CNKS
05-18-2004 17:41:47
 Re: farmall A in reply to tiny, 05-18-2004 17:30:16
No sasrcasm, but since you now know about the screen, why don't you just check it, instead of asking? (I have not read the other posts, as I usually read from the top down).
tiny
05-18-2004 18:10:41
 Re: Re: farmall A in reply to CNKS, 05-18-2004 17:41:47
To tired to go back to the garage and look I do know there is a elbow with a ferrle fitting there that is the gas line. :) Had to barrow my brother-in-laws crapsman lawn mowwer to mow my lawn so its been a long day.
CNKS
05-18-2004 18:12:28
 Re: Re: Re: farmall A in reply to tiny, 05-18-2004 18:10:41
Better to use a weed whacker.
tiny
05-18-2004 18:56:52
 Re: Re: Re: Re: farmall A in reply to CNKS, 05-18-2004 18:12:28
NOPE TO THE WEED WACKER lawns to big
CNKS
05-19-2004 18:20:33
 Re: Re: Re: Re: Re: farmall A in reply to tiny, 05-18-2004 18:56:52
I was just agreeing to your naming of your brother-in-law's mower.
