International farmall Loboy 154
Bob Oliver
05-19-2004 08:17:51
Our son has an Interational Farmall Loboy 154. It has no power to the transmission. Shaft works but nothing else does inside the case. Would you have any suggestions as to what to look for or how to fix it?
Would it be possible to obtain a diagram of the transmission?
Any help would be greatly appreciated.
Bob Oliver
lee
05-19-2004 12:08:55
 Re: International farmall Loboy 154 in reply to Bob Oliver, 05-19-2004 08:17:51
There are 2 shear bolts on either end of the shaft 1by the flywheel and other next to the creeper drive gear box use only a grade 5 or less If thats all turning pull the plug out of the bottom of the creeper unit if so equipt and check for frags the detent has I believe a 9/16 head bolt with a lockwasher spring and a ball Just in case you pull that out.The shift on the creeper should be smooth from low to high. My guess would the sun gears exploded. If that isnt it pull the seat/fender assembly off and peek in top of main trans housing
(Take the shift lever plate assembly off) good luck Let us know what happened
Bigdog
05-19-2004 09:15:25
Maybe this will help:
