cole planter
Kevin Harbin
05-19-2004 17:00:30
Does anyone here know how to how to modify a cole planter to fit my farmall cub? I have one I would like to use. I don't know if they're all the same or not. I'm fairly new to tractor planting. I've always used a hoe! Get's kinda old pretty quick. I can describe the planter if it would help. Kevin
Jim in NC
05-19-2004 18:36:09
 Re: cole planter in reply to Kevin Harbin, 05-19-2004 17:00:30
My Dad used a cole planter on his Super A. It was hooked by a clevis to a bar that bolted to a implememt stud on the inside of each of the final drives. It was raised and lowered by chains bolted to the back and on each side of the planter. The chains were attached to the rear cultivator lift arms. The layoff plow, mounted to the front lift, plowed the furrow for the seed, and he applied fertilizer to the row with a distributor at the same time. I think the same setup would work on a cub, but the hitching bar underneath would have to probably be a different length.
Kevin Harbin
05-19-2004 18:42:02
 Re: Re: cole planter in reply to Jim in NC, 05-19-2004 18:36:09
Thanks, Jim. That gives me a place to start. What part of NC? I'm in Seneca,SC(upper corner)
Jim in NC
05-20-2004 03:55:58
 Re: Re: Re: cole planter in reply to Kevin Harbin, 05-19-2004 18:42:02
I am in the central part of the state near Greensboro. If I can be any help, let me know. You could use the planter designed for the cub that works with the international fertilizer distributor. They can be expensive as I have seen only a couple sold.
