buying a international 504
steve mitchell
05-20-2004 13:30:31
have been considering buying an international 504 manufactured in early sixties. this machine is a little rough and last ran about a year ago. owner
has invoices showing considerable work done on engine and hydraulics ($1,500-$1,800) before it was parked due to the owners health. the owner wants about a thousand dollars for it. i am interested in older tractors but not very knowledgable. if you guys know of any reason to stay away from this particular model or have any input at all i would appreciate it. also it has a front end loader on it.
src
05-21-2004 11:01:52
 Re: buying a international 504 in reply to steve mitchell, 05-20-2004 13:30:31
If you don't buy it, let me know and I will.
Wardner
05-20-2004 14:53:39
I think you should leave your computer desk immediately and buy the tractor before someone else does.
steve
05-20-2004 18:39:53
 Re: Re: buying a international 504 in reply to Wardner, 05-20-2004 14:53:39
thanks for the advice wardner,might have to go look at it again. did i mention that it was a diesel?
Wardner
05-20-2004 21:19:00
 Re: Re: Re: buying a international 504 in reply to steve, 05-20-2004 18:39:53
The 504 diesel doesn't start very well. That would be a disadvantage on a loader tractor. However, how can you go wrong with a loader tractor that has had recent dealer repair, has modern hydraulics, and probably low hours under light duty. All this for $1000.
steve
05-22-2004 20:38:08
 Re: Re: Re: Re: buying a international 504 in reply to Wardner, 05-20-2004 21:19:00
went and looked at the 504 again. after some fresh fuel and a battery it started right up. one brake was hung up but that was easy to free.
problem with the hydraulics that raise and lower the 3 pt. and controls the auxilliary hyd. the valve assembly had been removed and taken apart. for what purpose we dont know.looks like it might need a new one, again, not very knowledgable. one question someone might be able to answer, the exhaust on this machine comes out of the manifold and goes directlt down and comes out under the rear axle, the hood looks origanal and there is no hole for the exhaust there. also it has something called a torque amplifier. not sure how it is supposed to work.also found out the machine has power steering. overall i guess it doesnt look too bad, going to check on hydraulic part and probably go for it.
Terry Barbee
06-12-2004 08:22:45
 Re: Re: Re: Re: Re: buying a international 504 in reply to steve, 05-22-2004 20:38:08
Torque amplifier? That's great! It's like splitting the gears. Where some manufacturers use hi-lo transmissions, IHC used the TA. Should you be using the tractor in a hard pull situation ie plowing, and it starts to bog down, just pull the TA. I have a 504 and it would be nice to have the TA on it, especially when I'm using the bushhog and trying to back up with the throttle in PTO position. That would help slow down the tractors ground speed.
What about brakes? Will yours lock the wheel to turn the tractor?
