Rear axle removal..help!
Dean Banta
05-21-2004 17:08:52
I have a fluid leak on my right rear axle and I need to remove to replace a gasket? I have taken the 4 bolts loose that seem to hold the axle in place but the axle is not coming out. Do I need to do something else or is the axle in so tight that I need to use the hammer (sledge) wrench??? Please help. Thanks in advance.
Oh yeah.. it's on a 1965 Farmall 140.
Dean
TDK
05-21-2004 21:27:52
 Re: Rear axle removal..help! in reply to Dean Banta, 05-21-2004 17:08:52
Remove the cover on backside of bullgear housing. Then you can remove the bolt that holds axle in. May take some coaxing to get it out though.
Dean Banta
05-22-2004 06:49:49
 Re: Re: Rear axle removal..help! in reply to TDK, 05-21-2004 21:27:52
Thanks for your help. I thought that rear cover was there for a reason. :-)
Wayne Swenson
05-21-2004 19:16:21
Most likely you have to remove the bolt that holds the bull gear to the inner end of the axle and take the bull gear off.
I am not familiar with the 140 but most tractors work that way.
Dean Banta
05-22-2004 06:58:35
 Re: Re: Rear axle removal..help! in reply to Wayne Swenson, 05-21-2004 19:16:21
