? about wet oil pan
Alvin NE WI
05-21-2004 18:16:22
On my 10-20 oil pan is always wet with oil.I guess the pan has a little seepage of oil from maybe strees cracks or whatever they are called. It isn't much but will leave oil spots on the floor. Would anybody know if i take the pan off and use KB weld on the inside of pan work or will i create other problems with KB stuff in side of pan. I am open to other ideas. Thank for any information--Alvin
nebraska cowman
05-22-2004 04:21:28
 Re: ? about wet oil pan in reply to Alvin NE WI, 05-21-2004 18:16:22
they like to leak around the flange that holds th 3 test cocks. very hard to fix. they were soldered when new but it is imposable to get them clean enough for solder to stick. I have seen lots of them brazed on but then you get it hot enought to melt the solder on the drain plug flange and have to do that too. If you can find the exact spot where it is leaking try cleaning it good and forcing the epoxy weld in the crack with your thumb. Worth a try.
