H - Farmall and shredder
chainsaw
05-21-2004 20:33:18
hello to all, i am thinking of buying a used Rhino 7 ft.drag type shredder with 2 solid wheels in rear. also has a hydraulic cylinder to raise and lower height. rancher wants $900.00. He bought it used himself and is only selling because he got a bigger one. he said its in good shape and he said it sells for $3,000.00 new. i would be pulling it with my H farmall. How is the quality of the Rhino brand? can this tractor handle 7 ft.? thanks for all comments, good or bad. chainsaw
NDS
05-22-2004 11:24:52
 Re: H - Farmall and shredder in reply to chainsaw, 05-21-2004 20:33:18
Will not say it won't work but 7 ft. Rino is a lot of cutter for H. Usually see them behind 706 IH 3020 JD etc.
Dave S
05-22-2004 05:40:52
I have a H with 37/16 bore and pull a 6' BMB shreader "now rhino", and it is a full load in 1st or 2nd gear when cutting tall brome grass short. (short being 2" to 3" tall) The price is right and i think you can pull it alright doing normal mowing. As someone else said you can always take a narrower cut.
Allan
05-22-2004 05:44:21
 Re: Re: H - Farmall and shredder in reply to Dave S, 05-22-2004 05:40:52
Dave,
I'm assuming your H has the step-up pistons?
As you already know, this gives 'em about a 50% power increase over a straight H.
Just wondering,
Allan
chainsaw
05-22-2004 08:06:17
 Re: Re: Re: H - Farmall and shredder in reply to Allan, 05-22-2004 05:44:21
hi allan, my h is stock now, i guess i would take smaller bites while shredding. thanks
Allan
05-22-2004 09:17:18
 Re: Re: Re: Re: H - Farmall and shredder in reply to chainsaw, 05-22-2004 08:06:17
Chain,
I hope it works for you 'cause I wanna do that too. Keep us informed will ya?
Thanks,
Allan
Tom W.
05-22-2004 05:11:30
i had a 7 ft bush hog on a H and it worked fine. If the mower has a long drive shaft, it may cause the PTO to bang inside the transmission. If it has a 2 peice shaft you should have no trouble. Make sure you have a PTO override coupler on your PTO shaft. With a 7 ft mower you have a lot of power to push you tractor when you try to stop. As long a the mower is turning you can't stop unless you take the transmission out of gear. you can get the coupler at a tractor store for about $60. The H will do fine, unless your cuting stuff that is as high as the tractor
Allan
05-22-2004 05:31:44
 Re: Re: H - Farmall and shredder in reply to Tom W., 05-22-2004 05:11:30
Thanks Tom,
Good info there. I wanna do just as Chainsaw is doing and use the H on my mower too, when I get the loader pulled off it.
Nice to know they have enough snort to pull it.
Allan
Allan
05-22-2004 05:02:15
Hi Chainsaw,
I think that Rhino is a good brand and yes, that is a very good price for it if it's in good shape.
I'm wondering if your H will pull it tho.
I put up a picture of my 7ft mower under "Crisis #407 Solved". For some reason, they seem wider when they are hooked up to the tractor. :>)
Allan
Ken
05-21-2004 21:05:08
What is a shredder?
chainsaw
05-21-2004 21:22:14
 Re: Re: H - Farmall and shredder in reply to Ken, 05-21-2004 21:05:08
a shredder is a bush hog. thanks
chainsaw
05-21-2004 20:37:35
the shredder is a RHINO GYRO 84. thaks again , chainsaw
steveormary
05-21-2004 21:18:37
 Re: Re: H - Farmall and shredder in reply to chainsaw, 05-21-2004 20:37:35
chainsaw;
You will need an orc because you dont have lpto. Low gear may be too fast if you are shreding heavy stuff,but you can always pull out a little. Ya,go ahead and get it,work the H a little.
steve
williamf
05-22-2004 05:57:09
 Re: Re: Re: H - Farmall and shredder in reply to steveormary, 05-21-2004 21:18:37
Steve, I started to read your post and thought, "Man, if he can train an orc to do his mowing maybe I can get an elf or two to help with the pruning and transplanting....No, wait a minute, he means 'over-running clutch." Darn;-)
Wm
steveormary
05-22-2004 12:27:06
 Re: Re: Re: Re: H - Farmall and shredder in reply to williamf, 05-22-2004 05:57:09
williamf;
orcs,elfs,goats,whatever makes the work easier.
steve
