engine trouble farmall bn help!!
ED
05-22-2004 17:22:12
my bn ran well but burned oil and smoked.tore down motor found oil on top of pistons found one broken oil ring and some scored rod bearings.sleeves and head,valves etc. all looked good. replaced rings and rod bearings motor stated right up and ran good, smokes the same if not worse. what did i miss here?could the valves be leaking that bad?it also spits some oil out muffler.any info would be much appreaciated before i tear it down again.thanks.
lee
05-22-2004 21:02:06
 Re: engine trouble farmall bn help!! in reply to ED, 05-22-2004 17:22:12
ya didn't build it worth a dang there pal...
Loren, and a better descr
05-22-2004 18:52:39
My 2 bits worth.
First off, did you do any measurements while it was apart? The bores may have been worn a lot and just thinking that you didn't mention breaking the glaze or honing? The valves would only cause a smoke problem if the guides were worn. Leaky valves have no oil running thru them unless you have a problem somewhere else. If you honed or roughed up the glaze on the cylinders and broke in the rings then I would ask how long have you run it since reassembly? If only a couple minutes, then the exhaust may be the culprit instead of the motor. If it smoked real bad before it would have left oil or at least soot in the pipe that may still be burning off. Loren
