clutch
derek carter
05-23-2004 08:42:00
i replaced the engine on my super a and now the clutch assembly dosnt work right.if u let the clutch disengage with the trans in nuetral it wont work no more. u have to turn the tractor off
crank it up and it works as long as u dont let the clucth disengage with the trans in nuetral.
anyone have any idea?
Wardner
05-23-2004 09:12:35
 Re: clutch in reply to derek carter, 05-23-2004 08:42:00
If you made no changes to the pressure plate, flywheel, or clutch disc, I would have to say the pilot bearing wasn't lubricated (if brass) or seized (if ball bearing).
