Super M cultivators
Jack
05-24-2004 06:21:46
I am in ne iowa and am lookingfor a set of front cultivators for super m.Are they still around ,worth having and not too expensive? I also have a 3pt so I guess if all else fails could use that.
thanks
jack
Bob in SE Nebraska
05-24-2004 13:52:39
 Re: Super M cultivators in reply to Jack, 05-24-2004 06:21:46
I don't see many two row cultivators at sales any more around here (Iowa & Nebraska). If you happen to find one at a sale they seem to go pretty cheap. I have a two row cultivator that I put on an H to take care of my sweet corn patch. A rear mounted cultivator has a big advantage in that it will not leave the tire tracks like the front mount cultivator will. Ease of mounting the 3 point is a big advantage too.
Bob
Allan
05-24-2004 14:15:34
 Re: Re: Super M cultivators in reply to Bob in SE Nebraska, 05-24-2004 13:52:39
Hi Bob,
Sounds like you just don't have the rear part of that front mounted cultivator.
The rear part attachment ran separate tool-bars & shanks down the middle and at both wheel tracks.
They mounted on the drawbar attaching points and were lifted by rods/cushion springs going up to the main lifting tubes.
Unless of course, you are talking about a completely different outfit than what I remember.
Allan
CNKS
05-24-2004 18:51:36
 Re: Re: Re: Super M cultivators in reply to Allan, 05-24-2004 14:15:34
Yes, front and rear mount cultivators were usually sold together. We always put sweeps behind the rear wheels to get rid of wheel tracks. Typically the front sweeps were run closer to the rows, while the rear ones just got what the front missed. We often removed the rear section and replaced it with the drawbar to pull tillage implements. With the advent of herbicides, the front mount is not as important as it used to be.
NDS
05-24-2004 08:40:03
I have put in thousands of hours on H and M with 2 and 4 row front mount cultivators and hundreds on SM with 2 and 4 row 3 point cultivators. No way I will ever use a front mount again. The front mount four rows are man killers especialy without power steering. Just my opinion.
Dick Davis
05-25-2004 06:57:21
 Re: Re: Super M cultivators in reply to NDS, 05-24-2004 08:40:03
Come on NDS you're older and stronger now and you know your doctor says you should get more exercise!
