super C touch control liquid
farmallsc
05-24-2004 14:01:11
does anyone know what the specs are for touch control fluid?
or is there another brand that works? there isnt a Case IH dealer around meso if theres an equivalent would help
wolfy
05-24-2004 18:12:32
 Re: super C touch control liquid in reply to farmallsc, 05-24-2004 14:01:11
For 52 years we've used regular hydraulic fluid(not the hydraulic-transmission) in our Super C touch control reservoir. Have we erred ? It works well but does leak a lot.
CNKS
05-25-2004 08:07:34
 Re: Re: super C touch control liquid in reply to wolfy, 05-24-2004 18:12:32
I meant that type of fluid used may be more important in tractors that have a combined hydraulic/transmission reservoir. The C doesn't. The seals are bad in your tractor. After 52 years they should be, fluid had nothing to do with it.
CNKS
05-24-2004 14:16:16
For a tractor that old, it really doesn't matter, for tractors that use the same fluid in the hydraulic system as in the transmission, it may. IH marketed the touch control before they started selling touch control fluid, they recommended 10W motor oil. To be safe, just purchase a fluid that meets Hy-Tran specs. It will probably be better than the original touch control fluid, anyway.
farmallsc
05-24-2004 14:54:24
 Re: Re: super C touch control liquid in reply to CNKS, 05-24-2004 14:16:16
So my 1951 super C, uses Hy tran, which is a type rather then a brand name. But 10w motor oil is what it used?
CNKS
05-24-2004 18:15:28
 Re: Re: Re: super C touch control liquid in reply to farmallsc, 05-24-2004 14:54:24
Use Hytran. My point was that when the touch control came out, Hytran, or earlier, touch control fluid, did not exist. At present any hydraulic fluid that meets Hytran specs is fine. Or, the older systems are not picky about what they use. HyTran is an IH brand name.
carm
05-24-2004 16:46:02
We use Hy tran or whatever meets the spec. in our c. It should say on the label
