1456
Sponz
05-25-2004 18:30:55
Can you get 150 horse out of a 1456 safely?? i'd like to pull a 22 foot field cultivater with it and i'd like to get that power to pull it safely
Mark B
05-25-2004 18:46:46
 Re: 1456 in reply to Sponz , 05-25-2004 18:30:55
Turn the fuel pump up a little and you should have the 150. Mine has turned 165hp for the last 8 years, that 407 is just about indestructible.
Allan
05-26-2004 03:00:37
 Re: Re: 1456 in reply to Mark B, 05-25-2004 18:46:46
Hi Mark,
What were they originally? Something like 130 or 135?
Thanks,
Allan
dhermesc
05-26-2004 09:29:24
 Re: Re: Re: 1456 in reply to Allan, 05-26-2004 03:00:37
A 1456 had 131 PTO and 118 at the drawbar. The 1466 was nearly the exact same in HP but had a little heavier transmission. A 1486 had about 10hp more at PTO and drawbar.
A 22' field cultivator should be within a 1456's power range without turning it up - in most soils - maybe just a little light. It's not uncommon for a turbo'd tractor to be producing less power - we had a 1466 that was down around 100hp for a while before we played with the turbo and brought it up around 150hp.
