756D HYd Relief Press
Redd
05-25-2004 19:02:42
I would like to change the hyd press on my 756. I no its fixed and located under the seat. I was told there are three settings available. Mine has an IHC part number but the I&T book says there should be a 1600 stamped in it. I'd like the highest setting of the three but would like to know what number I am looking for so I can buy the right one. thanks
K.B.
05-25-2004 21:12:56
 Re: 756D HYd Relief Press in reply to Redd, 05-25-2004 19:02:42
As far as I know, the smaller tractors like the 756 had 1800 psi releif valves from the factory. Parts book only shows part number 389033R93 for the 756, so that must be the 1800 PSI valve. Looking at the 66 series parts book I found 308288R93- 2000 PSI, 396729R93- 2300 PSI, and 543976R91- 2500 PSI.
