front main seal 1466
Yellott Canby
05-25-2004 19:44:56
Hello, I was wondering how bad a job it is to replace the front main seal on a 1466. Thanks ,YC
Jim J
05-26-2004 07:09:08
 Re: front main seal 1466 in reply to Yellott Canby, 05-25-2004 19:44:56
There is room to pull the pulley off with out pulling the front casting. All you will need to pull is the fan and shroud. I would also pull the radiator.
K.B.
05-25-2004 20:45:12
Shouldn't be too bad if you've got the equipment to handle it. Most guys just put a jackstand under the clutch housing, then unbolt the front bolster from the frame rails, then roll the whole front end/bolster/grill housing/radiator away. After that, you need a puller to remove the vibration dampner, and then the oil pump comes off.
