Greasing wide front on SC
riverbend
05-26-2004 08:16:45
I recently installed a wide front on my '53 Super C. There is only one grease fitting at the rear of the axle pivot shaft. At the front, in the center of the front axle, there is a large hollow pin, but neither size grease fitting will thread in there. How does the front of the pivot shaft get greased ?
Thanks
Greg
wildman
05-26-2004 19:01:19
 Re: Greasing wide front on SC in reply to riverbend, 05-26-2004 08:16:45
Where did you find a wide front and what would it cost. I need one thanks
riverbend
05-26-2004 19:15:31
 Re: Re: Greasing wide front on SC in reply to wildman, 05-26-2004 19:01:19
South of Austin, MN. $250.
I had placed an wanted ad in 'The Land', a twice a month paper out of Mankato (I think). Prices ranged up to $750. Martin Diffley (Lakeville, MN ) might still have one.
This one makes the tractor steer like a pig.
scotty
05-26-2004 10:43:55
Riverbend, If I understand you correctly, you are questioning about grease fitting on the center pivot. There is only one grease fitting there, there are helical groves milled in the brass bushing to distribute the grease over the length of that pin. hope this helps.
scotty
riverbend
05-26-2004 19:20:59
 Re: Re: Greasing wide front on SC in reply to scotty, 05-26-2004 10:43:55
My parts book calls that hollow pin a lubrication fitting, like the one on the brace, so I thought it should get grease. The operator's manual does not mention greasing a wide front. After I had used the tractor, I see that there is grease on the front of the pivot shaft.
