1466 TOURQUE AMP
LEWIS
05-26-2004 18:38:51
LABOR SET ASIDE ,WHAT IS THE AVERAGE COST OF REPAIR IF LO IS OUT OF THE TRACTOR .
Jeff OH
05-28-2004 05:36:24
 Re: 1466 TOURQUE AMP in reply to LEWIS, 05-26-2004 18:38:51
I would also replace pilot bearing and throw out bearing and have flywheel resurfaced. If splines are worn on the pressure plate center hub you might want to replace it also, especially if you use the pto much.
randy hall
05-26-2004 21:33:24
a good heavyduty ta is around $800 but while it is apart you would want to put in a new clutch and pto drive gear too.
LEWIS
05-27-2004 13:17:42
 Re: Re: 1466 TOURQUE AMP in reply to randy hall, 05-26-2004 21:33:24
THANKS FOR YOUR ADVICE AND TIME
