International 434
John
05-27-2004 09:38:45
I currently own an International 434. I have a couple issues I thought you all might be able to explain. The tractor starts fine, it has to have the choke pulled all the way out to run. It smokes when on a hill but not when running on level ground. It starts to get hot after running for about 30-60minutes depending on how hard the load is. The lift arms of the 3 point work fine but jerk every once in a while, and lastly while brush hogging when I get into thick grass it sometimes kicks to pto lever out of gear. Let me know what you think besides get rid of it. Thanks
Ben in KY
05-27-2004 13:10:33
 Re: International 434 in reply to John, 05-27-2004 09:38:45
Sounds like several things.
Clean the carb.
flush the cooling system and change thermostat, check belts and tension.
Check points plugs and timing.
Check hydraulic fluid for water/foaming/low level, change if foamy or milky.
Clean hydraulic suction screen.
PTO problem might be a bent PTO engagement lever not allowing the PTO to fully engage.
Good luck.
Allan
05-27-2004 13:21:08
 Re: Re: International 434 in reply to Ben in KY, 05-27-2004 13:10:33
And,
Don't forget the unwritten rule.
You never get rid of a red tractor!!! You keep putting money into 'em 'till your ears bleed. :>)
Allan
