H's throttle lever jumping out of high
Dave in CT
05-27-2004 11:26:55
Since the search engine on the archives isn't back up, I'll ask instead of search. My '47 H throttle lever jumps out of the teeth in the high range, back down to mid range, of it's own accord. I've heard folks speak of getting a friction throttle lever but I'd just as soon keep what I've got, if I can get it to stay. Has anyone fixed this with just a new compression spring under the pivot? If so, might you know a NAPA part number on this? If somone can tell me replacing that spring will fix it, I'll just bring the spring down to NAPA and get the closest replacement - my IHC dealer is too far away.
Tom W
05-27-2004 16:14:47
 Re: H's throttle lever jumping out of high in reply to Dave in CT, 05-27-2004 11:26:55
the tooth on the lever is replaceable. IH dealer should have them in stock. A new tooth fixed mine
rustyfarmall
05-28-2004 05:22:48
 Re: Re: H's throttle lever jumping out of high in reply to Tom W, 05-27-2004 16:14:47
The replaceable tooth is only on the later Hs and Ms, the earlier ones did not have this feature.
Name withheld for proctec
05-27-2004 15:25:14
This will not go over well with the correct crowd but it works for me. About 20 years ago was having trouble keeping throttle on my A fully open while bush hogging. So to temporarily solve problem until I could get new throttle plate I drilled 1/4 inch hole in plate just behind lever in full throttle position. Now throttle rests behind short 1/4 inch bolt when fully open Still intend to get new throttle plate when I have time and money.
jason r
05-27-2004 12:45:33
i have a used good throttle plate i'll sell you for $20 my e-mail is:
seblizzard@yahoo.com
scotty
05-27-2004 11:36:08
Dave, You got it on NAPA. Just get a spring with a little more lead in its pencil! You can also refile the saw tooth notches on your throttle control.I did this on the brake on my A.
scotty
rustyfarmall
05-27-2004 12:04:50
 Re: Re: H's throttle lever jumping out of high in reply to scotty, 05-27-2004 11:36:08
The catch on the lever also gets worn down, just build it up with your welder, and file it back to shape.
