HEAD GASKET: Witch side faces down?
Jason
05-27-2004 14:45:51
This might sound like a dumb question,but Im putting a head gasket on a 130 Farmall(C-123 engine)and Im not 100% sure how it goes. It has "This side out" stamped on it,but what does "Out" exactly mean? I I could see if it said up or down. One side is completely smooth where the other side has about a 1/8 ring going out around clylinder hole. Any help would be great. Thank You!!
Alan S.
05-28-2004 04:34:33
 Re: HEAD GASKET: Witch side faces down? in reply to Jason, 05-27-2004 14:45:51
The rolled edge against the block is the way to go. This will create a positive seal for the combustion chamber. I agree that the wording can be confusing, more than one head has been taken off because of sutch wording
Mike Androvich
05-27-2004 18:24:58
The side of the gasket with the rolled over rings goes against the block. Smooth side up to the head.
Jason
05-27-2004 19:10:21
 Re: Re: HEAD GASKET: Witch side faces down? in reply to Mike Androvich, 05-27-2004 18:24:58
Are you sure?? Why would they have "This side out" stamped on the part that faces the block? I don't know why they would use that kind of wording? Why not use "This side up" or this "This side down"?
Thanks for the help.
Wardner
05-27-2004 15:09:04
Sometimes it is stamped "top" or "up" or something similar.
If it isn't, find the oil gallery hole in the block and make sure that the gasket doesn't cover it. Chances are it will only go one way because the push rods will be blocked off by the gasket.
Red
09-20-2004 19:35:28
 Re: Re: HEAD GASKET: Witch side faces down? in reply to Wardner, 05-27-2004 15:09:04
Can anyone of you fellows tell me what this serial number means on a Farmall 130 (9158-J)?thanks ahead of time.Red
