Order Farmall Cub Parts Online
FARMALL CUB MOWER
GUY
05-27-2004 17:18:07
HAVE A FARMALL CUB WITH A 3 BLADE INTERNATIONAL DECK IT IS 60" DO NOT KNOW WHAT MODEL IT IS AND WHERE TO GET PARTS
Dale
05-28-2004 10:24:41
 Re: FARMALL CUB MOWER in reply to GUY, 05-27-2004 17:18:07
I appreciated seeing this post and the manual for the C3. I have one, well used, but seems to be a good solid mower. The drive belt on the top grove of the middle blade shaft wants to go to the middle grove where the belt to the right blade is. Since I can keep the drive belt in the middle position, I thought I'd raise the pulley on the right blade shaft, but can't get the pulley to move. It's a pulley with the three small stud bolts which I think comes apart, but don't know how. Can someone tell me how to do this? Thanks.
LWWinPA
05-28-2004 14:25:14
 Re: Re: FARMALL CUB MOWER in reply to Dale, 05-28-2004 10:24:41
The insert should have six hole in it. Take the bolts out of the holes they are in and put them into the emty holes. Then tighten down each bolt a litte at a time, they will push the insert out, keep them even.
Dale
06-01-2004 10:14:27
 Re: Re: Re: FARMALL CUB MOWER in reply to LWWinPA, 05-28-2004 14:25:14
To LWWinPA: I have tried that and the insert doesn't come out. I've had WD40 on it for a week. The small stud bolts could be twisted off very easily. I have even put the studs back into the original holes, retigthened them, and removed again thinking that the insert would work back and forth and come loose. I didn't see any of these pulleys in the manual. Do you know where I could see a drawing of this pulley and maybe I could understand how it comes apart. Thanks again. Dale
Rudi
05-27-2004 18:48:06
third party image
Guy:
Click on the Cub Manual link below, then to Cub Implements then to the Mowers. The C-2 and the C-3 mowers are there and there are drawings of them. Should help identify your mower.
I think the IH branded mowers were all made by Danco.
LWWinPA
05-27-2004 18:03:45
It is more than likely a C-3 Danco mower are the spindals adjustable if so then yes it is
