H hydraulics
Catskill Pete
05-28-2004 21:31:21
Working on a friends H, changing fluids and he doesn't have a manual, of course. So I'm trying to find out if the hydraulics have a seperate resevoir or if they share the same fluid as transmission and rear end. If it is seperate fluid for the hydraulics, what fluid does it call for?
Wayne Swenson
05-28-2004 21:40:42
 Re: H hydraulics in reply to Catskill Pete, 05-28-2004 21:31:21
The Lift-All uses 30 weight non-detergent oil. Drain the Lift-All with the small plug on the bottom of the unit. It needs 6 quarts to refill.
The transmission has 2 drains; 1 large one at the rear of the tractor and a smaller one that faces forward directly under the belt pulley location. I use a 85W-140 gear oil in my Farmalls.
If your friend is going to own the tractor and use it, please get the owner's manual to know how to take care of the "old girl".
Catskill Pete
05-29-2004 17:20:05
 Re: Re: H hydraulics in reply to Wayne Swenson, 05-28-2004 21:40:42
Thanks, Ive been telling him to order,at least an owners manual for it, for a couple of months. Some people just don't get the message.
