Hydraulic ??s for M return line
nick inWI
05-30-2004 09:11:14
I am putting a aftermarket pump on my M for 2-way hydraulics. I am going to run the feed to the pump from the belly pump reservoir, then from the pump to the "in" on the 2 spool valve. Where can I put the "out" line to(return line from valve)?? One of the 90 deg. fittings on the side??
Bruce Wa.
05-30-2004 09:28:31
 Re: Hydraulic ??s for M return line in reply to nick inWI, 05-30-2004 09:11:14
Put a tee in the fill pipe on top and run your return in there. It will not return through the side fittings.
nick inWI
05-30-2004 10:53:33
 Re: Re: Hydraulic ??s for M return line in reply to Bruce Wa., 05-30-2004 09:28:31
If I put a tee in will it ooze from the air hole or not?
rustyfarmall
05-30-2004 12:48:58
 Re: Re: Re: Hydraulic ??s for M return line in reply to nick inWI, 05-30-2004 10:53:33
No, it should not ooze.
