Smokin' Restored B
Wayne Montgomer
05-30-2004 14:43:44
Model B restored (?)by local person. Assembled replacement head, heard clatter, took off, found it had high compression pistons, and ground out head to conform with prior head (supposedly). Back to together and smoke! Tell me, as I am not a mechanic.
bfarmall@msn.com
05-30-2004 21:57:34
 Re: Smokin' Restored B in reply to Wayne Montgomery, 05-30-2004 14:43:44
Are you sure he put the pistons in correct? If they are turned wrong they will hit the head.
Wayne
05-31-2004 11:38:32
 Re: Re: Smokin' Restored B in reply to bfarmall@msn.com, 05-30-2004 21:57:34
I'll be! You guys on here are just the greatest. All of you seem like "you've been there, done that" and are so liberal in sharing your knowledge. Both of these suggestions make for sense.
Dave_Id
05-30-2004 15:56:16
My first thought would be head gasket.
Wayne Montgomery
05-30-2004 19:50:56
 Re: Re: Smokin' Restored B in reply to Dave_Id, 05-30-2004 15:56:16
Thanks for that prompt reply. That sounds simple enough so will have a look at it - with someone else. Wayne
