correct carb for 8-16 tractor
The Iceman
05-30-2004 18:20:29
Does anyone know if a late international 8-16 tractor uses the same carb as an early 10-20 tractor? Thank you.
Zak
05-30-2004 20:27:57
 Re: correct carb for 8-16 tractor in reply to The Iceman, 05-30-2004 18:20:29
If the carb you refer to has a two-bolt flange, as opposed to the later 3-bolt style, then yes. I had one of the three-bolters that I know came off a 10-20. I just sold an earlier 2-bolt job and I was told it could also be used on the 8-16 even though it was stamped 10-20 on it. Regards, Zak
