runs with a miss
Chris Nighsonge
05-30-2004 22:25:51
I bought 51 farmall M it ran well but is know missing ? It does burn oil. I put new plugs, wires,etc on ran well then started missing again. Any help or comments would be great Thank you Chris
CNKS
05-31-2004 06:13:05
 Re: runs with a miss in reply to Chris Nighsonger, 05-30-2004 22:25:51
It could be many things -- As to the oil burning, if it is bad enough one or more plugs will foul quickly. Pull the plugs and clean them if oil fouled. If the problem disappears, then recurs, you will know what causes it. As a temporary fix, use a hotter plug, or one designed to fire in oil, if such plugs still exist. My dad had an H with the same problem. Different plugs "fixed" the problem. It was overhauled soon after.
George Willer
05-31-2004 05:42:00
I have a '51 M I bought on eBay. The price was good because of the Saginaw 3 pt, live hydraulics, and the wide front. When I picked it up, I was disappointed that it was missing on one cylinder. It was obvious from all the new parts thrown at it that the P.O. had tried hard to get it running right before deciding to sell it. I figured it must have a pitted valve seat, but when I got it home I ran a compression check to see which cylinder was bad. They were all good! Further examination found a bent and displaced push rod... one exhaust valve wasn't opening at all. Straightened the push rod and it runs like a new one.
George Willer
Allan
05-31-2004 05:54:06
 Re: Re: runs with a miss in reply to George Willer, 05-31-2004 05:42:00
Atta Boy George!!
Ya gotta love it when a plan comes together like that. Ya done good!
Allan
Dave in CT
05-30-2004 23:26:15
Would you detail the 'etc' - does that mean new points, condenser, cap and rotor? Is it battery ignition or magneto? The missing that happened after the replacements start after running for how long? After warming up or working for a few days? How long after you got it or how much did you use it before the first missing started? One thought in answer to the burning oil is that the plugs might be fouling. How do they look now? Oily-black, dry fluffy black or another color? Do you know you have good fuel flow?
