706 hyd, question,
chris
05-31-2004 05:43:40
my 706 while under load if you hit the brakes, turning or if one wheel is spinning the ta will let loose like you shoved the clutch down when you let off the brake it will jump out from under you, my question, what pump runs what, what does the front pump run and what does the back pump run
Pa
05-31-2004 06:15:58
 Re: 706 hyd, question, in reply to chris, 05-31-2004 05:43:40
The front pump runs the power steering the breaks and the T/A. These are controlled by the MCV(multiple control valve) on the left side of the trans. the rear pump runs your 3 pt hitch and your remote hyd. The power take off has its own pump contained. The breaks and steering will have priority over the T/A if there were to be a leak or a loss in pressure. The valve that conrolls this operation could be malfunctioning or you could have a linkage out of adjustment.
