What IH is this?
Leo
05-31-2004 10:07:32
This tractor looks like some of the F models shown in the photo album on this site. F20,22,12 ect. It has front mounted steering gear & the steering shaft runs down the top of the hood. The air cleaner is mounted in front on the left side by the steering gear. The only # I found on it is 1500DB with the IH logo behind the B. How do I determine what year & model this tractor is? Thanks, Leo.
rex
05-31-2004 13:54:10
 Re: What IH is this? in reply to Leo, 05-31-2004 10:07:32
if it's a f-12 or f-14 the serial number will be under the gas tank on the tank bracket. if the steering column is flat against the body then it's an f-12, if it is raised then it's a f-14. could you tell us what size the tires are? that's an indicator too as to what model it is.
Dave_Id
05-31-2004 10:32:02
Can you post a picture? If the steering gear is bare, and not enclosed, it may be a Farmall Regular.
